Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
Gently pry open button and remove button.
Do this for each of the 3 buttons remaining.
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
Use the Torx 6 screwdriver to remove these 2 screws.
Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
You can use your hands to simply pull apart the top casing from the bottom casing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
