メインコンテンツにスキップ
Sidekick II LCD Screen Replacement
必要な工具と部品
  1. Sidekick II LCD Screen Replacement, Outer Casing: 手順 1、 1の画像 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II LCD Screen Replacement: 手順 2、 2の画像 1 Sidekick II LCD Screen Replacement: 手順 2、 2の画像 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II LCD Screen Replacement: 手順 3、 1の画像 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II LCD Screen Replacement: 手順 4、 1の画像 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II LCD Screen Replacement: 手順 5、 1の画像 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II LCD Screen Replacement, LCD Screen: 手順 6、 2の画像 1 Sidekick II LCD Screen Replacement, LCD Screen: 手順 6、 2の画像 2
    • Flip the screen to its up position.
    • Remove screen from keyboard.
  7. Sidekick II LCD Screen Replacement: 手順 7、 1の画像 1
    • Remove 4 screws from back of screen.
  8. Sidekick II LCD Screen Replacement: 手順 8、 1の画像 1
    • Separate screen from housing with your fingers.
  9. Sidekick II LCD Screen Replacement: 手順 9、 3の画像 1 Sidekick II LCD Screen Replacement: 手順 9、 3の画像 2 Sidekick II LCD Screen Replacement: 手順 9、 3の画像 3
    • Remove 4 screws
    • Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
  10. Sidekick II LCD Screen Replacement: 手順 10、 1の画像 1
    • Remove LCD protective cover with your fingers.
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
michael albaum
メンバー登録日: 01/20/10
87 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G19
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 3,646
