メインコンテンツにスキップ
Shower Head Replacement
必要な工具と部品
  1. Shower Head Replacement, Shower Head: 手順 1、 1の画像 1
    • Use your hand to loosen the old shower head from the pipe. This should be fairly easy, as most shower heads have a textured grip on the joint.
    • Make sure the water is turned off to the shower.
  2. Shower Head Replacement: 手順 2、 1の画像 1
    • Once the shower head is loosened, remove it and set it aside.
  3. Shower Head Replacement: 手順 3、 1の画像 1
    • Remove the old plumbing tape from the threads of the pipe, and throw it away.
  4. Shower Head Replacement: 手順 4、 1の画像 1
    • Grab your roll of plumbing tape and wrap the tape approximately twice around the threads of the pipe.
    • Be sure to wrap the tape tightly to prevent leaks.
  5. Shower Head Replacement: 手順 5、 1の画像 1
    • Begin installing the new shower head by threading it onto the pipe.
  6. Shower Head Replacement: 手順 6、 1の画像 1
    • Use your hands to tighten the new shower head back onto the pipe, using a wrench if needed.
    • Make sure it is tightly connected!
  7. Shower Head Replacement: 手順 7、 1の画像 1
    • Turn on the water and enjoy your new shower head!
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Aaron Bartfeld
メンバー登録日: 02/23/15
205 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-3, Green Winter 2015 Cal Poly, Team 12-3, Green Winter 2015人のメンバー
CPSU-GREEN-W15S12G3
4 メンバー
7のガイドは作成済み
4件のガイドコメント
Great post. Very informative and easy to follow! Beautiful hand model, absolutely superb! Is he single by any chance?
nprewitt - 返信
My shower isn’t broken I just keep looking at the incredible hand model! Wow! I would break my shower head if these hands would fix it
Abby - 返信
What a helpful guide . And Wow! I couldn't help but notice some phenomenal hand modeling. Those hands are going places that's for sure!
Ronaldo Villa - 返信
What does his feet look like? Haha.
Sounds like fake replies. 3 people saying the same thing on the same exact day. Gtfoh.
Kimmy (Kimmy Kimmy Bang Bang) - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 42
今までの合計 3,514
