メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shower Handle O-ring Replacement
必要な工具と部品
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: 手順 1、 1の画像 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
    FixBotに聞いてみる
  2. Shower Handle O-ring  Replacement: 手順 2、 1の画像 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    FixBotに聞いてみる
  3. Shower Handle O-ring  Replacement: 手順 3、 1の画像 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    FixBotに聞いてみる
  4. Shower Handle O-ring  Replacement: 手順 4、 1の画像 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
    FixBotに聞いてみる
  5. Shower Handle O-ring  Replacement: 手順 5、 2の画像 1 Shower Handle O-ring  Replacement: 手順 5、 2の画像 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
    FixBotに聞いてみる
ゴール
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cori Fitzpatrick
メンバー登録日: 03/20/16
213 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-6, Lauer Spring 2016 Michigan Tech, Team 1-6, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G6
1 メンバー
1のガイドは作成済み
4件のガイドコメント
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - 返信 共有
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - 返信 共有
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
Jess - 返信 共有
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 43
過去 30 日: 198
今までの合計 26,018
