メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shower Arm Replacement
必要な工具と部品
  1. Shower Arm Replacement, Shower Arm: 手順 1、 3の画像 1 Shower Arm Replacement, Shower Arm: 手順 1、 3の画像 2 Shower Arm Replacement, Shower Arm: 手順 1、 3の画像 3
    • Turn off the main water supply. Turn the wheel clockwise (right) to shut off water (if there is 2 wheels, turn both of them clockwise). Turn it until it stops — do not force it.
    • If the valve has a lever handle, rotate it 90° so it is perpendicular to the pipe.
    • In a house, the main shutoff valve is typically located in the basement, near the water meter, or where the main water line enters the home. In a condo, the shutoff may be inside a utility closet, mechanical panel, or bathroom access panel. If unsure, contact building management.
    FixBotに聞いてみる
  2. Shower Arm Replacement: 手順 2、 3の画像 1 Shower Arm Replacement: 手順 2、 3の画像 2 Shower Arm Replacement: 手順 2、 3の画像 3
    • Use an adjustable wrench to loosen the nut that connects the shower head to the shower arm.
    • Turn the nut counterclockwise until the shower head comes off.
    FixBotに聞いてみる
  3. Shower Arm Replacement: 手順 3、 1の画像 1
    • Gently slide the decorative flange (the round metal cover) away from the wall.
    • This exposes the threaded connection where the shower arm enters the wall.
    FixBotに聞いてみる
  4. Shower Arm Replacement: 手順 4、 1の画像 1
    • Grip the shower arm with a wrench covered with a cloth or rag to protect the finish and turn it counterclockwise. Continue turning until the shower arm fully unscrews from the wall fitting.
    • Use a cloth or rag between the wrench and the shower arm to prevent scratching the finish.
    FixBotに聞いてみる
  5. Shower Arm Replacement: 手順 5、 1の画像 1
    • Use a cloth or a rag to remove old plumber’s tape residue or debris from the threaded fitting inside the wall.
    FixBotに聞いてみる
  6. Shower Arm Replacement: 手順 6、 1の画像 1
    • Wrap plumber’s tape clockwise 2–4 times around the threaded end of the new shower arm.
    FixBotに聞いてみる
  7. Shower Arm Replacement: 手順 7、 3の画像 1 Shower Arm Replacement: 手順 7、 3の画像 2 Shower Arm Replacement: 手順 7、 3の画像 3
    • Screw the new shower arm clockwise into the wall fitting until it is securely installed.
    • Slide the decorative flange back against the wall.
    FixBotに聞いてみる
  8. Shower Arm Replacement: 手順 8、 2の画像 1 Shower Arm Replacement: 手順 8、 2の画像 2
    • Reattach the showerhead and use an adjustable wrench to turn the nut clockwise to secure it to the shower arm.
    FixBotに聞いてみる
  9. Shower Arm Replacement: 手順 9、 1の画像 1
    • Turn the water supply back on and test the shower for leaks around the connection.
    FixBotに聞いてみる
終わりに
After installing the new shower arm and reconnecting the shower head, turn the main water supply back on and test the shower for leaks. If you notice any dripping around the connection, tighten the fittings slightly or apply additional plumber’s tape. Once the connections are secure, your shower arm replacement is complete.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tim
メンバー登録日: 01/20/26
193 ポイント
1ガイドが承認済み
チーム
York University, Team 1-9, Woodhouse Winter 2026 York University, Team 1-9, Woodhouse Winter 2026人のメンバー
YORK-WOODHOUSE-W26S1G9
2 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 38
今までの合計 143
