メインコンテンツにスキップ
Shop-Vac MC150A Motor Replacement
必要な工具と部品
  1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: 手順 1、 1の画像 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Motor Replacement, Remove the top cover: 手順 2、 2の画像 1 Shop-Vac MC150A Motor Replacement, Remove the top cover: 手順 2、 2の画像 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Motor Replacement: 手順 3、 1の画像 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Motor Replacement: 手順 4、 1の画像 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Motor Replacement, Disconnect the switch: 手順 5、 3の画像 1 Shop-Vac MC150A Motor Replacement, Disconnect the switch: 手順 5、 3の画像 2 Shop-Vac MC150A Motor Replacement, Disconnect the switch: 手順 5、 3の画像 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: 手順 6、 2の画像 1 Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: 手順 6、 2の画像 2
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Motor Replacement: 手順 7、 2の画像 1 Shop-Vac MC150A Motor Replacement: 手順 7、 2の画像 2
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Motor Replacement: 手順 8、 1の画像 1
    • Separate the clip from the green wire and transfer it to the replacement motor.
  9. Shop-Vac MC150A Motor Replacement, Motor: 手順 9、 2の画像 1 Shop-Vac MC150A Motor Replacement, Motor: 手順 9、 2の画像 2
    • Remove the motor bracket.
  10. Shop-Vac MC150A Motor Replacement: 手順 10、 1の画像 1
    • Turn the part over to the other side.
    • Use the socket wrench remove the bolt securing the aluminum plate.
  11. Shop-Vac MC150A Motor Replacement: 手順 11、 1の画像 1
    • Unscrew the two Phillips head screws holding the cover to the motor.
    • After removing the cover to the motor, you can replace the motor.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Ngunlian
メンバー登録日: 02/08/16
732 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-2, Baechle Spring 2016 IUPUI, Team 1-2, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S1G2
5 メンバー
13のガイドは作成済み
2 件のコメント
Where do I buy a new motor?????
Gerald Mikel - 返信
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 78
過去 30 日: 323
今までの合計 26,366
