メインコンテンツにスキップ
Sharper Image SVC430 Tripod Nut Replacement
必要な工具と部品
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: 手順 1、 2の画像 1 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: 手順 1、 2の画像 2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: 手順 2、 2の画像 1 Sharper Image SVC430 Tripod Nut Replacement: 手順 2、 2の画像 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: 手順 3、 3の画像 1 Sharper Image SVC430 Tripod Nut Replacement: 手順 3、 3の画像 2 Sharper Image SVC430 Tripod Nut Replacement: 手順 3、 3の画像 3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: 手順 4、 2の画像 1 Sharper Image SVC430 Tripod Nut Replacement: 手順 4、 2の画像 2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: 手順 5、 1の画像 1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: 手順 6、 3の画像 1 Sharper Image SVC430 Tripod Nut Replacement: 手順 6、 3の画像 2 Sharper Image SVC430 Tripod Nut Replacement: 手順 6、 3の画像 3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: 手順 7、 1の画像 1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: 手順 9、 1の画像 1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: 手順 10、 1の画像 1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: 手順 11、 1の画像 1
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: 手順 12、 2の画像 1 Sharper Image SVC430 Tripod Nut Replacement: 手順 12、 2の画像 2
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
終わりに
作成者
4人の作成者と共同で作成されました。
Kathryn Mattingly
メンバー登録日: 01/29/16
698 ポイント
6のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-6, Matravers Spring 2016 University of Kentucky Louisville, Team 1-6, Matravers Spring 2016人のメンバー
LOUISVILLE-MATRAVERS-S16S1G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 215
