メインコンテンツにスキップ
Sharper Image M18A Speaker Replacement
必要な工具と部品
  1. Sharper Image M18A Speaker Replacement, Position: 手順 1、 1の画像 1
    • Position the tablet on a flat surface in front of you and place it face down.
  2. Sharper Image M18A Speaker Replacement, Opening the Tablet: 手順 2、 1の画像 1
    • Remove silver side panels with prying tool by snapping them of the outer casing of the tablet.
  3. Sharper Image M18A Speaker Replacement, Removing the Outer Casing: 手順 3、 1の画像 1
    • -Remove 9 screws by unscrewing the ones behind the panels with a bit driver. There are four screws on one side and five on the other. All which need to be removed.
  4. Sharper Image M18A Speaker Replacement, Separate the Tablet: 手順 4、 2の画像 1 Sharper Image M18A Speaker Replacement, Separate the Tablet: 手順 4、 2の画像 2
    • Snap the back cover of the tablet off of the front cover, hence removing the tablet’s outer casing. Be cautious when removing because the speaker wires connect the two casings of the tablet.
  5. Sharper Image M18A Speaker Replacement, Identifying the Speakers: 手順 5、 1の画像 1
    • The speakers are located on the inside of the back casing. They are two small black ovals thats are connected with two sets of black and red wires and connect to the logic board.
  6. Sharper Image M18A Speaker Replacement, Removing the Speakers: 手順 6、 2の画像 1 Sharper Image M18A Speaker Replacement, Removing the Speakers: 手順 6、 2の画像 2
    • Using a prying tool lift the edge of the speakers where the wires are attached. Follow the wires connected to the speakers and remove the black tape. There is one piece of tape for each speaker and three pieces of tape that attach them to the logic board. Remove all carefully.
  7. Sharper Image M18A Speaker Replacement, Unmounting the Speakers: 手順 7、 2の画像 1 Sharper Image M18A Speaker Replacement, Unmounting the Speakers: 手順 7、 2の画像 2
    • Using the wire snippers, cut the defective speaker wires as close to the circuit board as possible. Then gently remove the defective speakers from their housings with your hands.
  8. Sharper Image M18A Speaker Replacement, Installing the New Speakers: 手順 8、 3の画像 1 Sharper Image M18A Speaker Replacement, Installing the New Speakers: 手順 8、 3の画像 2 Sharper Image M18A Speaker Replacement, Installing the New Speakers: 手順 8、 3の画像 3
    • First plug in the Soldering iron and wait for it to heat up. If your soldering iron has a dial, adjust the setting somewhere between 15 and 40 Watts..
    • Then connect the prepped speaker wire to the same spot where the previous wire was removed from.
    • Next take the new speakers and solder the ends of each set of wires to the logic board. The red wires go to the positive and the black wire goes to negative,which is labeled on the logic board. Do this by touching the soldering iron to the twisted copper wire for about a second to heat the wire.
    • Next, touch the solder to the soldering iron, so that a small amount of solder melts and forms a small bead between the surfaces being connected. (Avoid pooling of solder material by keeping this step between 3-4 seconds)
    • Lastly secure the new wires with the black tape and place the speaker back into its original slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Mary Macedo
メンバー登録日: 10/22/14
1 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-8, Shastany Fall 2014 UMass Dartmouth, Team 1-8, Shastany Fall 2014人のメンバー
UMASSD-SHASTANY-F14S1G8
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 275
