はじめに
You'll be replacing the keyboard component of the Sharp PC - MM20!
必要な工具と部品
Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
Also, remove the flat cable from the track pad to the laptop.
ある他の人がこのガイドを完成しました。
