メインコンテンツにスキップ
Shark Vertex Pro IZ682H Brush Roller Belt Replacement
必要な工具と部品
  1. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller: 手順 1、 1の画像 1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
  2. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller Belt: 手順 2、 1の画像 1
    • Turn the three plastic locks to the unlocked position and remove the crevice tool.
    • Use T9 and T15 screwdrivers to remove the seven screws.
  3. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 手順 3、 2の画像 1 Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 手順 3、 2の画像 2
    • Use an opening tool on the edges of the casing and pull off the thin plastic coverings on both sides.
    • Expect to hear snapping noises.
    • Pull the plastic coverings off the powerhead.
  4. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 手順 4、 1の画像 1
    • Remove the six screws using a T15 Torx security screwdriver.
    • Remove the plastic headcover.
  5. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 手順 5、 1の画像 1
    • Remove the seven screws using the T10 and T15 Torx security screwdriver.
    • Lift the covering and motor assembly enough to see the belt.
  6. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: 手順 6、 1の画像 1
    • Remove the belt and power nozzle.
    • When reinstalling, be sure the belt is tightly secured around the gear grooves.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tyree Brooks
メンバー登録日: 10/26/22
486 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Botvin Fall 2022 UMass Dartmouth, Team 3-2, Botvin Fall 2022人のメンバー
UMASSD-BOTVIN-F22S3G2
2 メンバー
5のガイドは作成済み
2 件のコメント
Thanks for the instruction. It helped, however, I cannot find the brush anywhere that goes to this vacuum (the one that attaches to the belt)
Eric - 返信
Hey I am looking for the brush. Did you manage to find it or find an alternative?
John Melo -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 47
過去 30 日: 236
今までの合計 6,385
