メインコンテンツにスキップ
Shark UltraCyclone CH951 U4 Power Control Board Replacement
必要な工具と部品
  1. Shark UltraCyclone CH951 U4 Power Control Board Replacement, Dust Cup: 手順 1、 3の画像 1 Shark UltraCyclone CH951 U4 Power Control Board Replacement, Dust Cup: 手順 1、 3の画像 2 Shark UltraCyclone CH951 U4 Power Control Board Replacement, Dust Cup: 手順 1、 3の画像 3
    • Press the dust cup release button and gently pull the dust cup away from the body of the vacuum.
  2. Shark UltraCyclone CH951 U4 Power Control Board Replacement, Casing: 手順 2、 2の画像 1 Shark UltraCyclone CH951 U4 Power Control Board Replacement, Casing: 手順 2、 2の画像 2
    • Use a TR9 Torx screwdriver to remove the two 8.7 mm screws previously behind the dust cup.
  3. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 3、 1の画像 1
    • Remove the two 12.2 mm screws underneath the dust cup button using a TR9 Torx screwdriver.
  4. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 4、 1の画像 1
    • Remove the 13.9 mm screw beneath the charging port using a TR9 Torx screwdriver.
  5. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 5、 1の画像 1
    • Use the TR9 Torx screwdriver to remove two 11.6 mm screws that hold the exterior motor in place.
    • They are located underneath where the dust cup previously was and above the exterior motor.
  6. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 6、 3の画像 1 Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 6、 3の画像 2 Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 6、 3の画像 3
    • Run an iFixit Opening Tool under the casing along the vacuum body until the shell is removed starting around the attachment port, and sliding down towards the charging port.
    • If necessary, apply gentle force.
  7. Shark UltraCyclone CH951 U4 Power Control Board Replacement, Power Control Board: 手順 7、 3の画像 1 Shark UltraCyclone CH951 U4 Power Control Board Replacement, Power Control Board: 手順 7、 3の画像 2 Shark UltraCyclone CH951 U4 Power Control Board Replacement, Power Control Board: 手順 7、 3の画像 3
    • Press down on the connection point of the white wire and disconnect it.
    • The connector looks like a white latch. Push down on the edge to pop it out of place.
  8. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 8、 1の画像 1
    • Remove the 8.7mm screw in the center of the button control board.
  9. Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 9、 3の画像 1 Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 9、 3の画像 2 Shark UltraCyclone CH951 U4 Power Control Board Replacement: 手順 9、 3の画像 3
    • Remove the board by using your fingers and lifting the component from the body of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jessica Beck
メンバー登録日: 01/24/25
587 ポイント
4のガイドは作成済み
チーム
Colorado Mesa University, Team 1-3, Kinney Spring 2025 Colorado Mesa University, Team 1-3, Kinney Spring 2025人のメンバー
CMU-KINNEY-S25S1G3
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 130
