メインコンテンツにスキップ
Shark Ultimate Professional Mode Display Replacement
必要な工具と部品
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: 手順 1、 3の画像 1 Shark Ultimate Professional Mode Display Replacement, Mode Display: 手順 1、 3の画像 2 Shark Ultimate Professional Mode Display Replacement, Mode Display: 手順 1、 3の画像 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: 手順 2、 2の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 2、 2の画像 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: 手順 3、 3の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 3、 3の画像 2 Shark Ultimate Professional Mode Display Replacement: 手順 3、 3の画像 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: 手順 4、 3の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 4、 3の画像 2 Shark Ultimate Professional Mode Display Replacement: 手順 4、 3の画像 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: 手順 5、 2の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 5、 2の画像 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: 手順 6、 2の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 6、 2の画像 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: 手順 7、 3の画像 1 Shark Ultimate Professional Mode Display Replacement: 手順 7、 3の画像 2 Shark Ultimate Professional Mode Display Replacement: 手順 7、 3の画像 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Drew Carff
メンバー登録日: 10/23/17
868 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017人のメンバー
USFT-LEAHY-F17S1G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 15
今までの合計 657
