メインコンテンツにスキップ
Shark Ultimate Professional Circuit Board Replacement
必要な工具と部品
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 1 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 2 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: 手順 1、 3の画像 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Circuit Board Replacement: 手順 2、 2の画像 1 Shark Ultimate Professional Circuit Board Replacement: 手順 2、 2の画像 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Circuit Board Replacement: 手順 3、 1の画像 1
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
  4. Shark Ultimate Professional Circuit Board Replacement: 手順 4、 3の画像 1 Shark Ultimate Professional Circuit Board Replacement: 手順 4、 3の画像 2 Shark Ultimate Professional Circuit Board Replacement: 手順 4、 3の画像 3
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Circuit Board Replacement: 手順 5、 2の画像 1 Shark Ultimate Professional Circuit Board Replacement: 手順 5、 2の画像 2
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
  6. Shark Ultimate Professional Circuit Board Replacement: 手順 6、 2の画像 1 Shark Ultimate Professional Circuit Board Replacement: 手順 6、 2の画像 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
  7. Shark Ultimate Professional Circuit Board Replacement: 手順 7、 3の画像 1 Shark Ultimate Professional Circuit Board Replacement: 手順 7、 3の画像 2 Shark Ultimate Professional Circuit Board Replacement: 手順 7、 3の画像 3
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
  8. Shark Ultimate Professional Circuit Board Replacement: 手順 8、 1の画像 1
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Drew Carff
メンバー登録日: 10/23/17
868 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G4, Leahy Fall 2017 USF Tampa, Team S1-G4, Leahy Fall 2017人のメンバー
USFT-LEAHY-F17S1G4
3 メンバー
10のガイドは作成済み
4 件のコメント
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - 返信
where do I buy it's circuit board?
egovieira - 返信
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - 返信
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 32
今までの合計 3,073
