はじめに
This guide will inform users how to remove and replace the Shark Steam Pocket Mop power cable.
必要な工具と部品
Begin by removing the 8 quarter inch phillips head screws found along the back panel
Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
