メインコンテンツにスキップ
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement
必要な工具と部品
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: 手順 1、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: 手順 1、 2の画像 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 2、 1の画像 1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 3、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 3、 2の画像 2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 4、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 4、 2の画像 2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 5、 3の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 5、 3の画像 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 5、 3の画像 3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 6、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 6、 2の画像 2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 7、 3の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 7、 3の画像 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 7、 3の画像 3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 8、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 8、 2の画像 2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 9、 3の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 9、 3の画像 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 9、 3の画像 3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 10、 2の画像 1 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: 手順 10、 2の画像 2
    • Wiggle the brush roller upwards from the left and right side slots.
終わりに
作成者
3人の作成者と共同で作成されました。
Daniel Ceja
メンバー登録日: 01/24/19
277 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019人のメンバー
CPSU-WHITE-W19S19G3
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 958
