この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
A damaged hose will not allow the vacuum to function properly. This guide will assist in the replacement process. The hose is electrically attached to the other components of the vacuum. Removal of the hose will require electrical components.
必要な工具と部品
3 の人々がこのガイドを完成させました。
2 件のコメント
Very helpful! I got a sock super stuck. I tried all the conventional methods to get it out but ended up needing to take the hose apart. Excellent instructions that got the job done with no lasting damage.
My Shark Vertex looks suspiciously like this unit. Maybe I should return it before I have problems that require me to do all this!
My first Shark lasted almost 20 years without a hitch. It was finally taken down by a plastic part inside the unit that I have been unable to locate. It would be quite an easy repair save the plastic part securing the handled hose to the body.
Yikes!
