メインコンテンツにスキップ
Shark Rotator Powered Lift-Away Speed Headlight Replacement
必要な工具と部品
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: 手順 1、 2の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: 手順 1、 2の画像 2
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 2、 2の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 2、 2の画像 2
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 3、 1の画像 1
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 4、 2の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 4、 2の画像 2
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 5、 1の画像 1
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 6、 1の画像 1
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 7、 1の画像 1
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 8、 1の画像 1
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 9、 3の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 9、 3の画像 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 9、 3の画像 3
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 10、 1の画像 1
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 11、 3の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 11、 3の画像 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 11、 3の画像 3
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 12、 3の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 12、 3の画像 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 12、 3の画像 3
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 13、 3の画像 1 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 13、 3の画像 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: 手順 13、 3の画像 3
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dakota Rodriguez-Ransom
メンバー登録日: 10/08/18
605 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S4G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 15
今までの合計 1,996
