はじめに
The Shark Rotator Powered Lift-Away has one rotatory belt. The belt is responsible for the mechanical rotations of the brushroll. Without it, the vacuum will not function. The vacuum's belt is designed to last approximately 7 years. Replacement of the belt is needed to keep the vacuum at optimal working condition. This replacement guide demonstrates how to replace the belt in the vacuum.
必要な工具と部品
Remove the three 14.3 mm screws with a T20 screwdriver.
there is also a small ~13mm PH0 screw on the center of the edge in front of the roller between the 2 other screws indicated that must be removed before you can get the cover off.
Turn the vacuum around.
Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
Remove the belt from the gear.
Thank you for posting this. I couldnt find these instructions anywhere else.
2 の人々がこのガイドを完成させました。
2 件のコメント
Where can we buy belts in UK?
where cn i get a belt for this vaccum
As a general comment. Take care and good luck with this procedure. Instructions are fine, I found just one small screw wasn't covered. Front centre in roller cavity near the centre tab. Taking apart was straightforward, then it all feels like a jelly. Bits start moving and falling off as you turn the vacuum around, spring fell off plus other bits. Eventually got it back together, but not so easy, very fiddly. Anyway it works now. MikeM
Mike Mason - 返信
