メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The Shark Rotator Powered Lift-Away has one rotatory belt. The belt is responsible for the mechanical rotations of the brushroll. Without it, the vacuum will not function. The vacuum's belt is designed to last approximately 7 years. Replacement of the belt is needed to keep the vacuum at optimal working condition. This replacement guide demonstrates how to replace the belt in the vacuum.
  1. Turn the vacuum on its side. Using a quarter, twist the three green locks to the unlock position. Pull the bottom roller brush cover to open the vacuum.
    • Turn the vacuum on its side.
    • Using a quarter, twist the three green locks to the unlock position.
    • Pull the bottom roller brush cover to open the vacuum.
  2. Using a T20 screwdriver, remove the five 15.9 mm screws on the outside cover.
    • Using a T20 screwdriver, remove the five 15.9 mm screws on the outside cover.
  3. Remove the three 14.3 mm screws with a T20 screwdriver. Remove the three 14.3 mm screws with a T20 screwdriver.
    • Remove the three 14.3 mm screws with a T20 screwdriver.
  4. Remove the two 14.3 mm screws under the wheels with a T20 screwdriver bit.
    • Remove the two 14.3 mm screws under the wheels with a T20 screwdriver bit.
  5. Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
    • Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
  6. Remove the single  13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
    • Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
  7. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
    • Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
  9. Turn the vacuum around. Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights. Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
    • Turn the vacuum around.
    • Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
  10. Remove both of the headlight covers with the spudger. Remove both of the headlight covers with the spudger.
    • Remove both of the headlight covers with the spudger.
  11. Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel. Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel. Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
    • Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
  12. Remove the two 13.4 mm screws with a T20 bit screwdriver.
    • Remove the two 13.4 mm screws with a T20 bit screwdriver.
  13. Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
    • Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
  14. Remove the visible side of the belt from the gear with a spudger. Remove the visible side of the belt from the gear with a spudger. Remove the visible side of the belt from the gear with a spudger.
    • Remove the visible side of the belt from the gear with a spudger.
  15. Remove the grey panel from the opposite side, by uncrewing the single  13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
    • Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
  16. Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward. Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
    • Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
  17. Remove the belt from the gear. Remove the belt from the gear.
    • Remove the belt from the gear.
終わりに
Dakota Rodriguez-Ransom
メンバー登録日: 2018年10月08日
587 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018人のメンバー
CPSU-WHITE-F18S4G6
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 6
過去 7 日: 21
過去 30 日: 115
今までの合計 1,139
