はじめに
This disassembly is necessary to remove multiple features such as the brush, the brush belt, and the headlights.
必要な工具と部品
Push the lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
ある他の人がこのガイドを完成しました。
