メインコンテンツにスキップ
Shark Rotator Powered Lift-Away Brush Belt Replacement
必要な工具と部品
  1. Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 手順 1、 2の画像 1 Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: 手順 1、 2の画像 2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 2、 1の画像 1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 3、 2の画像 1 Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 3、 2の画像 2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 4、 2の画像 1 Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 4、 2の画像 2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 5、 1の画像 1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 6、 2の画像 1 Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 6、 2の画像 2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 7、 1の画像 1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Brush Belt Replacement, Brush Belt: 手順 8、 1の画像 1
    • Pry tab out with a flat head screwdriver or any wedge-like tool.
  9. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 9、 3の画像 1 Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 9、 3の画像 2 Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 9、 3の画像 3
    • Gently press in on brush to detach.
    • Pull brush down and out.
  10. Shark Rotator Powered Lift-Away Brush Belt Replacement: 手順 10、 1の画像 1
    • Slide the belt off of the gear.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cameron Ngai
メンバー登録日: 09/27/17
718 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S9-G3, Banghart Fall 2017 Cal Poly, Team S9-G3, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G3
4 メンバー
12のガイドは作成済み
コメント 1 件
where did you get new belts? I bought a set from Amazon for a Shark NV752 and the belts are a bit to large.
John Doe - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 82
今までの合計 15,152
