はじめに
If the brush does not spin and the motor still works, then the brush belt may be worn down or damaged.
This guide will aid in replacing that belt.
必要な工具と部品
Push the lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
6 の人々がこのガイドを完成させました。
