はじめに
Low suction could mean that it's time to check the foam and felt filters. Once removed, the filters should be examined for dirt or damage and cleaned or replaced respectively. Dirt and damage can cause blockage in the suction of the vacuum resulting in the vacuum not being able to pick up dirt effectively.
Locate and press the tab on the top of the removable canister.
Lift the canister away from the body of the vacuum.
もう少しです!
終わりに
