はじめに
The vacuum comes with several hose attachments and pathways through which debris passes through. To clean or remove blockages from hose attachments, it may be necessary to remove the hose and wand attachments.
Place the vacuum upright and locate the attachment you want removed.
ある他の人がこのガイドを完成しました。
4 件のコメント
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
ac002n1397 - 返信
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
