メインコンテンツにスキップ
Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement
  1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement, Hose and Wand Attachment: 手順 1、 1の画像 1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Place the vacuum upright and locate the attachment you want removed.
  2. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 2、 3の画像 1 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 2、 3の画像 2 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 2、 3の画像 3
    • Slide the attachments off of the end of the wand.
    • Some attachments may have a "Release" button--if so, hold down the button while sliding the attachment off.
    • The back of the vacuum has slots to hold up to two vacuum attachments. To store, simply place the attachment onto the circular slots.
  3. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 3、 2の画像 1 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 3、 2の画像 2
    • Locate the button that says “Release Wand” and press down.
    • Press button while lifting upwards on the handle at the top of the wand.
  4. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 4、 2の画像 1 Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: 手順 4、 2の画像 2
    • Locate the black hose on the back of the vacuum.
    • Locate the silver release levers on the top and bottom of the hose.
    • Press on the silver release levers and pull up and away from the device to release the hose.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Samantha Woo
メンバー登録日: 10/02/17
330 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G7
4 メンバー
10のガイドは作成済み
4 件のコメント
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
Sandra Groeninger - 返信
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
ac002n1397 - 返信
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
Gilda Allen - 返信
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
Gilda Allen - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 114
今までの合計 18,404
