メインコンテンツにスキップ
Shark Rotator Lift-Away Speed Filter Replacement
  1. Shark Rotator Lift-Away Speed Filter Replacement, Filter: 手順 1、 3の画像 1 Shark Rotator Lift-Away Speed Filter Replacement, Filter: 手順 1、 3の画像 2 Shark Rotator Lift-Away Speed Filter Replacement, Filter: 手順 1、 3の画像 3
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Lay the vacuum pod flat with the bottom facing towards you.
    • Pull the silver release latch and lift away from the body of the vacuum from the bottom.
  2. Shark Rotator Lift-Away Speed Filter Replacement: 手順 2、 1の画像 1
    • Lift the front cover off the face of the vacuum body.
    • Pull out the filter.
    • This filter should be replaced or washed once a year.
  3. Shark Rotator Lift-Away Speed Filter Replacement: 手順 3、 3の画像 1 Shark Rotator Lift-Away Speed Filter Replacement: 手順 3、 3の画像 2 Shark Rotator Lift-Away Speed Filter Replacement: 手順 3、 3の画像 3
    • Rest the vacuum pod upright.
    • Press down on the buttons on either side of the handle labeled “dust cup release.”
    • Lift the dust cup away from from the body of the vacuum to uncover the foam filter.
    • In most Shark manuals, the vacuum pod is referred to as the "Lift-Away Pod."
  4. Shark Rotator Lift-Away Speed Filter Replacement: 手順 4、 2の画像 1 Shark Rotator Lift-Away Speed Filter Replacement: 手順 4、 2の画像 2
    • Lift the foam filter and filter frame out of the center of the vacuum to unveil the felt filter.
    • Remove the felt filter by lifting the pull-tab.
    • These filters should be replaced or washed every three months.
    • Do not use the vacuum without the dust cup and filters in place.
終わりに
作成者
3人の作成者と共同で作成されました。
Julia Sullivan
メンバー登録日: 10/02/17
107 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G7
4 メンバー
10のガイドは作成済み
3 件のコメント
I cleaned all filters vacuum a rug and then went to regular floors and the vacuum stopped all together I don't know what it is belt looks new
donnaweitz4849@gmail.com - 返信
I cleaned all filters let them dry then replaced to vacuum started vacuum and it ran less than 5minutes and it shut down
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 18
過去 30 日: 92
今までの合計 10,794
