メインコンテンツにスキップ
Shark Rotator Lift-Away Speed Brushroll Motor Replacement
必要な工具と部品
  1. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll: 手順 1、 1の画像 1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 2、 2の画像 1 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 2、 2の画像 2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 3、 2の画像 1 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 3、 2の画像 2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
  4. Shark Rotator Lift-Away Speed Brushroll Motor Replacement, Brushroll Motor: 手順 4、 1の画像 1
    • Remove the five 5mm Torx #9 screws on the front side.
  5. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 5、 1の画像 1
    • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
  6. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 6、 1の画像 1
    • Remove the top panel by lifting the top piece off of the bottom.
    • There will be loud clicking noises.
  7. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 7、 1の画像 1
    • If you are trying to remove the belt, you may skip to the next step.
    • Remove the 7.5mm Torx #20 screw in front of the motor.
    • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
  8. Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 8、 2の画像 1 Shark Rotator Lift-Away Speed Brushroll Motor Replacement: 手順 8、 2の画像 2
    • Remove the panel to reveal the motor screw.
    • Remove the 7.5mm Torx #20 motor screw.
    • Remove the motor.
終わりに
作成者
2人の作成者と共同で作成されました。
Weston Mongomery
メンバー登録日: 10/02/17
201 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G7
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 34
今までの合計 3,750
