メインコンテンツにスキップ
Shark Professional Steam Pocket Mop Steam Nozzle Replacement
必要な工具と部品
  1. Shark Professional Steam Pocket Mop Steam Nozzle Replacement, Steam Nozzle: 手順 1、 1の画像 1
    • Press the mop head release button to remove it from the steam mop body.
  2. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 2、 1の画像 1
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 3、 1の画像 1
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 4、 1の画像 1
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  5. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 5、 1の画像 1
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  6. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 6、 1の画像 1
    • Use needle nose pliers to compress metal clamp .
  7. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 手順 7、 1の画像 1
    • Pull the nozzle out of the tube.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Michael Raymond
メンバー登録日: 02/12/18
154 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S15G1
4 メンバー
14のガイドは作成済み
2 件のコメント
This was fantastic. Only place I found on how to disassemble mop head. If i were you, I would go a little further and explain how to clean the nozzle. Use a paper clip or 20 gauge wire to push build up out. If that does not work use a small drill bit ( be careful to drill straight or you could damage the wall or jacket . This worked for me. Saved me $30. Had a problem locating this sight. Maybe some way to make it easier to locate would help. Thanks for your posting.
Mike Cunningham - 返信
Do you know if I can soak this part in clr? I can't seem to clean it well enough.
Kelsey Harper -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 88
今までの合計 4,510
