メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのShark Professional Steam Pocket Mopを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 1、 2の画像 1 Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 1、 2の画像 2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 2、 3の画像 1 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 2、 3の画像 2 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 2、 3の画像 3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 3、 2の画像 1 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 3、 2の画像 2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 4、 3の画像 1 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 4、 3の画像 2 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 4、 3の画像 3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 5、 3の画像 1 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 5、 3の画像 2 Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 5、 3の画像 3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Front Panel Disassembly: 手順 6、 1の画像 1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
作成者
2人の作成者と共同で作成されました。
Brett Wilson
メンバー登録日: 02/12/18
992 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S15G1
4 メンバー
14のガイドは作成済み
コメント 1 件
Here is a video to help with dismantling if you'd like to see the possible original guide first posted on YouTube by George Robles September 16, 2015 years before.
https://youtu.be/18mMbbMjqzs
No one knew or posted before me because I looked everywhere and why I created the video.
But I am curious where you got your information from if it was not my video.
George Robles - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 84
今までの合計 3,962
