メインコンテンツにスキップ
Shark Pet Perfect II Battery Replacement
必要な工具と部品
  1. Shark Pet Perfect II Battery Replacement, Battery: 手順 1、 3の画像 1 Shark Pet Perfect II Battery Replacement, Battery: 手順 1、 3の画像 2 Shark Pet Perfect II Battery Replacement, Battery: 手順 1、 3の画像 3
    • Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
  2. Shark Pet Perfect II Battery Replacement: 手順 2、 3の画像 1 Shark Pet Perfect II Battery Replacement: 手順 2、 3の画像 2 Shark Pet Perfect II Battery Replacement: 手順 2、 3の画像 3
    • Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
  3. Shark Pet Perfect II Battery Replacement: 手順 3、 3の画像 1 Shark Pet Perfect II Battery Replacement: 手順 3、 3の画像 2 Shark Pet Perfect II Battery Replacement: 手順 3、 3の画像 3
    • Pull the battery out of the compartment.
    • Carefully disconnect the quick disconnect couplers.
    • The Couplers may be tightly secured so it may be necessary to use a small flat device to carefully loosen the coupler.
    • Be sure to use an ESD safe tool like the nylon spudger when working with wires and batteries—this will prevent injury and/or device damage.
  4. Shark Pet Perfect II Battery Replacement: 手順 4、 1の画像 1
    • Completely remove the old battery from the vacuum .
終わりに
4 の人々がこのガイドを完成させました。
添付文書
作成者
3人の作成者と共同で作成されました。
Christine Robles
メンバー登録日: 06/27/17
113 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G5, Liner Summer 2017 UW Tacoma, Team S1-G5, Liner Summer 2017人のメンバー
UWT-LINER-SU17S1G5
4 メンバー
8のガイドは作成済み
12件のガイドコメント
Removed the single screw but cover will not come off. What do you do?
Adalyn Etelamaki - 返信
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
PradSim Promo Ads - 返信
Will it run on cord only
ligthelf - 返信
NO. Requires batteries.
Jim DeCamp -
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Jim DeCamp - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 19
過去 30 日: 103
今までの合計 19,166
