メインコンテンツにスキップ
Shark Navigator Roller Brush Compartment Replacement
必要な工具と部品
  1. Shark Navigator Roller Brush Compartment Replacement, Roller Brush Compartment: 手順 1、 1の画像 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Compartment Replacement: 手順 2、 2の画像 1 Shark Navigator Roller Brush Compartment Replacement: 手順 2、 2の画像 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Compartment Replacement: 手順 3、 1の画像 1
    • Remove the white plastic cover to expose the roller compartment underneath.
終わりに
19 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jeremiah Shyne
メンバー登録日: 03/27/15
1,403 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015人のメンバー
UMASSD-KISH-S15S5G4
4 メンバー
16のガイドは作成済み
17件のガイドコメント
Tried driver tips on two MULTI-TIP tools (standard & metric), but none fit. Looks like a very small 6-sided star w/a hole n middle. Trying again tomorrow w/mini metric set. I agree, 10 screws, two under wheels is way too much trouble for something you need quick access to often for brush cleaning. The hose has several places where it comes apart very easily. I was impressed, but this roller plate ruined it.
Bettie Howard - 返信
Nice guide very easy to follow took awhile to complete only because vacuum parts I took off with very dirty had to clean other than that the guide was very very useful and very very easy to follow appreciate it!!!
Kenneth Johnson - 返信
Easy to get off but hard to get it bqck on. I put the name of my shark and took it apart and it was for a lift away which I dont have now I can’t get it back together HELP
Gail Jezik - 返信
Where did you find the replacement brush bar? Im having a heard time locating one.
meghmrr - 返信
This truly is not intended for the user to replace the roller, but rather, they would like you to pay a lot more to take it in to service! To have a star screw with hole - which is what mine has - not Philips - and under wheels and 10 of them of varying length, and good luck, like Bettie Howard said, getting the driver to fit into the deeper holes! I have no adapter or extension - means you’d have to purchase a special tool. Luckily for me, I didn’t have to replace the roller, but rather sucked a USB cable which quickly wrapped around it. I was trying to salvage it, but after 2.5 screws later, decided it was better to cut the cable!
a_1_jensen - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 39
過去 30 日: 208
今までの合計 87,455
