メインコンテンツにスキップ
Shark Navigator Lightweight Upright Motor Replacement
必要な工具と部品
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: 手順 1、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: 手順 1、 2の画像 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: 手順 2、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 2、 2の画像 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: 手順 3、 1の画像 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: 手順 4、 3の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 4、 3の画像 2 Shark Navigator Lightweight Upright Motor Replacement: 手順 4、 3の画像 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: 手順 5、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 5、 2の画像 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: 手順 6、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 6、 2の画像 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: 手順 7、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 7、 2の画像 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: 手順 8、 3の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 8、 3の画像 2 Shark Navigator Lightweight Upright Motor Replacement: 手順 8、 3の画像 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: 手順 9、 1の画像 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: 手順 10、 3の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 10、 3の画像 2 Shark Navigator Lightweight Upright Motor Replacement: 手順 10、 3の画像 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: 手順 11、 3の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 11、 3の画像 2 Shark Navigator Lightweight Upright Motor Replacement: 手順 11、 3の画像 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: 手順 12、 2の画像 1 Shark Navigator Lightweight Upright Motor Replacement: 手順 12、 2の画像 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Suzie
メンバー登録日: 10/02/17
527 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S4G6
3 メンバー
12のガイドは作成済み
2 件のコメント
Where does one buy the replacement motor?
Michael De La Rosa - 返信
Where can I get spares??
ck
Clive Kingscote - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 50
今までの合計 9,628
