はじめに
Use this guide to ensure your Shark Navigator Lift-Away Upright Vacuum with Self-Cleaning Brushroll (UV725BXBRN) isn't damaged or needs a replacement. Before you start your repair make sure you have a flathead driver or a coin to turn the locks. Also, unplug your vacuum. The new technology implented in these newer models of Shark vacuums make it hard for the consumer to replace the Brushroll like the previous models. The manufactures replace it for you. So, the fix doesn’t work contact Shark so they can further assist you.
必要な工具と部品
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
2 の人々がこのガイドを完成させました。
