はじめに
When the roller belt has snapped or your vacuum's roller brush is not spinning, you should look into replacing your roller belt.
必要な工具と部品
Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
4 の人々がこのガイドを完成させました。
20 件のコメント
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
Try amazon…replacement belt for shark navigator freestyle cordless vacuum
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
The brush stops tolling after a few seconds. How do I trouble shoot this?
Same happens to me. I took it all apart; there was not much hair in the mechanisms at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next.
