はじめに
The roller brush helps to pick up dirt deep in the carpet or stuck to the floor. If the roller brush is no longer rotating, you may have to remove it and clean or replace it. Follow these steps to remove the roller brush.
必要な工具と部品
Lift the latches on both sides of the vacuum to release the dust canister.
Remove the dust canister from the vacuum by lifting it up.
9 の人々がこのガイドを完成させました。
コメント 1 件
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
