はじめに
If the handle for your Steam Pocket Mop gets loose and falls off, or if you would like to remove the handle for easy storage, use this guide to walk you through the process. You will need a Phillips #2 screwdriver for this replacement.
必要な工具と部品
もう少しです!
To disassemble your device, follow these instructions in reverse order.
終わりに
ある他の人がこのガイドを完成しました。
