メインコンテンツにスキップ
Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment Replacement
  1. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: 手順 1、 2の画像 1 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement, Accessory Hose Attachment: 手順 1、 2の画像 2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: 手順 2、 2の画像 1 Shark Lift-Away Professional Steam Pocket Mop Accessory Hose Attachment  Replacement: 手順 2、 2の画像 2
    • Disconnect the hand-held steamer unit from the accessory extension hose.
    • Grip the hand-held steamer and push down on the two release buttons.
    • Gently pull the accessory extension hose out in a horizontal motion until it disconnects.
    • When reassembling, be sure to insert the base of the hand-held unit first.
    • If you have any problems with the hand-held steamer locking into place, please consult our Troubleshooting Page.
    • While the accessory extension hose is not pictured here, the procedure is the same.
終わりに
作成者
2人の作成者と共同で作成されました。
Rachel Howe
メンバー登録日: 10/17/18
261 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team S1-G3, Rose Fall 2018 UW Tacoma, Team S1-G3, Rose Fall 2018人のメンバー
UWT-ROSE-F18S1G3
4 メンバー
10のガイドは作成済み
2 件のコメント
What if it won't allow to power on once reassembled? The light flashes but won't click on.
Aubrey Diaz - 返信
really?? take it on and off with more words.... how about something helpful like where this stupid little rubber band goes so that the trigger is actuated when the unit is placed in the floor mopper. pat yourself on the back you rewrote the basic user instructions and called it a repair. thanks for the complete waste of my time
Jessica Mcallister - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 29
今までの合計 2,619
