はじめに
This replacement guide uses a metal spudger, T20 Torx screwdriver, and a large plastic opening tool. This guide will show the user how to open the device casing, access the brush roll band, and replace the band.
CAUTION: Use care when using the metal spudger, as the edges of the tool are sharp and can cut you if you are not careful.
パーツ
パーツは指定されていません。
Press and slide the “access brush roll” buttons towards the text and lift plastic brush roll cover off.
ある他の人がこのガイドを完成しました。
