はじめに
Is your Shark ION Robot S87 sound alarm blinking or is there no suction anymore ? The primary reason for these occurrences is dirty filters. Dirty filters are caused by debris and hair being sucked into the vacuum. To avoid this, change your filter periodically because they get dirty, and may even crack from various items. If you are experiencing this issue, here is an easy guide to fix it.
必要な工具と部品
Flip the Shark ION Robot so that the underside is facing up.
Hold the button on the bottom of the vacuum, and slide the tray away from the device.
