メインコンテンツにスキップ
Shark ION Robot R75 Side Brush Replacement
必要な工具と部品
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: 手順 1、 3の画像 1 Shark ION Robot R75 Side Brush Replacement, Side Brush: 手順 1、 3の画像 2 Shark ION Robot R75 Side Brush Replacement, Side Brush: 手順 1、 3の画像 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
終わりに
作成者
2人の作成者と共同で作成されました。
Kyle Wilbourn
メンバー登録日: 01/25/20
513 ポイント
4のガイドは作成済み
チーム
2 件のコメント
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - 返信
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 24
過去 30 日: 132
今までの合計 6,398
