はじめに
The drive motor/wheel assemblies are a vital component to the R75.
the assembly includes:
- a drive motor
- a small gear system
- a drive wheel
- a motor controller
- the R75’s suspension system
Each of these components can be replaced individually, however, you will rarely find a single component being sold as a replacement, whereas the complete assembly can be ordered.
You may want to remove the drive assembly in order to replace a failed drive motor or to clean out hair or debris from the drive wheel. If a drive motor has failed, you should notice your robot’s ability to move become severely impaired, if not fail entirely.
It is important to occasionally inspect the wheels for any sort of wear and debris build up.
必要な工具と部品
Flip the R75 over so that the underside is facing up.
Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
Remove the battery cover.
3 の人々がこのガイドを完成させました。
6件のガイドコメント
I appreciate the step-by-step instructions with pictures... this was very helpful. However, my rv750 doesn't have the screws by the wheel assembly.
I've removed the screws, but it appears that I will need to separate the bottom from the top to access the wheel assemblies. Do you have a step=by step for the rv750 that has the wheel assembly enclosed?
The right wheel ass has a small gear striped inside, can you buy the small gears to repair the wheel drive?
I'm going to try these from Walmart
