はじめに
If you cannot charge your Shark ION Robot, there may be a problem with the charging dock motherboard, which requires a replacement.
Damage to the charging dock could cause damage to the battery when trying to charge it or even a heat reaction, which could cause fires or other malfunctions.
必要な工具と部品
Remove the three Torx T6 screws on the underside of the charging dock.
Lift off the lower case.
もう少しです!
終わりに
