はじめに
If you need to replace the motor of your Shark Flex DuoClean, follow this guide. To remove the motor, soldering skills are required. See this guide for soldering instructions.
必要な工具と部品
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
I know it is absolutely essential to have a security bit on here to change the belt as you wouldn't want anyone accidently changing it.
Remove the four 15 mm T10 screws on the underside of the vacuum.
Orient the vacuum so you are looking down at the open garage of the vacuum.
Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
6 の人々がこのガイドを完成させました。
7 件のコメント
Can this motor we test it before taking it out
craigfranz - 返信
Can this motor be tested before taking it out?
craigfranz - 返信
How do I know if the motor is burned out
It must be for a different model slightly or a newer model because mine has Allen head security screws and not torques and my motor is screwed in not just popped in.
What the hell is a "spudger"?
