この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Soldering skills are required.
必要な工具と部品
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
もう少しです!
終わりに
