メインコンテンツにスキップ
Shark Flex DuoClean Motherboard Replacement
必要な工具と部品
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: 手順 1、 2の画像 1 Shark Flex DuoClean Motherboard Replacement, Garage Door: 手順 1、 2の画像 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: 手順 2、 2の画像 1 Shark Flex DuoClean Motherboard Replacement, Side Component: 手順 2、 2の画像 2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: 手順 3、 2の画像 1 Shark Flex DuoClean Motherboard Replacement: 手順 3、 2の画像 2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: 手順 4、 1の画像 1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: 手順 6、 1の画像 1
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: 手順 7、 2の画像 1 Shark Flex DuoClean Motherboard Replacement: 手順 7、 2の画像 2
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: 手順 9、 1の画像 1
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: 手順 10、 1の画像 1
    • Desolder the motherboard wires using wire cutters.
終わりに
作成者
2人の作成者と共同で作成されました。
Samantha Mickelson
メンバー登録日: 10/08/18
496 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G5
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 1,390
