メインコンテンツにスキップ
Shark Cordless Pet Perfect Rear Motor Replacement
必要な工具と部品
  1. Shark Cordless Pet Perfect Rear Motor Replacement, Rear Motor: 手順 1、 3の画像 1 Shark Cordless Pet Perfect Rear Motor Replacement, Rear Motor: 手順 1、 3の画像 2 Shark Cordless Pet Perfect Rear Motor Replacement, Rear Motor: 手順 1、 3の画像 3
    • Remove the Dust Cup Container from the motor housing.
  2. Shark Cordless Pet Perfect Rear Motor Replacement: 手順 2、 3の画像 1 Shark Cordless Pet Perfect Rear Motor Replacement: 手順 2、 3の画像 2 Shark Cordless Pet Perfect Rear Motor Replacement: 手順 2、 3の画像 3
    • Remove the five 14mm screws with the PH2 Bit from the motor housing and pull the housing apart.
  3. Shark Cordless Pet Perfect Rear Motor Replacement: 手順 3、 3の画像 1 Shark Cordless Pet Perfect Rear Motor Replacement: 手順 3、 3の画像 2 Shark Cordless Pet Perfect Rear Motor Replacement: 手順 3、 3の画像 3
    • Pull the motor upward and away from the the housing.
  4. Shark Cordless Pet Perfect Rear Motor Replacement: 手順 4、 2の画像 1 Shark Cordless Pet Perfect Rear Motor Replacement: 手順 4、 2の画像 2
    • With the soldering tool separate the motor from the gray wire and the black wire.
    • Turn the motor to the other side. Then separate the motor from the two red wires, and the white wire.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ben Dzugen
メンバー登録日: 02/02/17
383 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S16G2
4 メンバー
11のガイドは作成済み
2 件のコメント
OK that tells me how to replace it but nothing else. Every article written about this item isn't really about repairing or troubleshooting, they're about taking apart some components, with a screwdriver. Not really helpful at all. But nice try.
Katea Monsta - 返信
I disassembled my 18 Volt SV780N because a new battery with 6 hours charge was not powering any response. In item 2, there is another screw which holds the case together. It is on the front side where the snout attaches——on the rim of the intake and is plainly visible. The handle on the unit does split in half and contains the mini circuit board which is the brain of this vac—-mounted under the off-on switch. I found this to be covered in micro dust (Just as the interior is elsewhere). I used an artist’s paint brush to clean it. If you have this apart, it might be also useful to brush off (Or wipe) the dust off the motor. This allows the motor another degree of cooling which perhaps prolongs its life. I suggest mounting the battery in the motor half so wiring can be safety placed into the proper recesses making the unit easier to close… Good Luck!
Siamese Cat - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 3,241
