メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shank Button Replacement
必要な工具と部品
  1. Shank Button Replacement, Shank Button: 手順 1、 3の画像 1 Shank Button Replacement, Shank Button: 手順 1、 3の画像 2 Shank Button Replacement, Shank Button: 手順 1、 3の画像 3
    • Remove your loose button (if necessary).
    • If the button is already missing, remove any loose threads from your garment.
    • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
  2. Shank Button Replacement: 手順 2、 3の画像 1 Shank Button Replacement: 手順 2、 3の画像 2 Shank Button Replacement: 手順 2、 3の画像 3
    • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
    • Thread your needle.
    • Pull the thread until two equal parts are on either side of the needle.
    • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
  3. Shank Button Replacement: 手順 3、 3の画像 1 Shank Button Replacement: 手順 3、 3の画像 2 Shank Button Replacement: 手順 3、 3の画像 3
    • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
    • Pull the thread until the knot rests on the fabric.
    • Insert your needle into the shank on the back of your button.
    • Pull the thread until the button rests on the fabric.
    • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
  4. Shank Button Replacement: 手順 4、 3の画像 1 Shank Button Replacement: 手順 4、 3の画像 2 Shank Button Replacement: 手順 4、 3の画像 3
    • To tie off your thread, insert the needle back into the fabric near your previous stitches.
    • Pull thread until there is a small loop (do not pull flush with fabric).
    • Insert the needle into the thread loop and pull through.
    • Pull the thread until the loop closes and a knot is formed.
  5. Shank Button Replacement: 手順 5、 3の画像 1 Shank Button Replacement: 手順 5、 3の画像 2 Shank Button Replacement: 手順 5、 3の画像 3
    • Trim any excess thread from the button area.
    • Enjoy your newly repaired item!
ゴール
作成者
2人の作成者と共同で作成されました。
Rebekah Kilpatrick
メンバー登録日: 09/20/23
121 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-13, Martin Fall 2023 University of North Texas, Team 1-13, Martin Fall 2023人のメンバー
UNT-MARTIN-F23S1G13
1 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 77
今までの合計 909
