メインコンテンツにスキップ
Separating Rear Board
必要な工具と部品
  1. Separating Rear Board, Remove Battery: 手順 1、 3の画像 1 Separating Rear Board, Remove Battery: 手順 1、 3の画像 2 Separating Rear Board, Remove Battery: 手順 1、 3の画像 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. Separating Rear Board, Remove Trigger Buttons: 手順 2、 2の画像 1 Separating Rear Board, Remove Trigger Buttons: 手順 2、 2の画像 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. Separating Rear Board, Remove Screws: 手順 3、 2の画像 1 Separating Rear Board, Remove Screws: 手順 3、 2の画像 2
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. Separating Rear Board, Unclip Covers: 手順 4、 3の画像 1 Separating Rear Board, Unclip Covers: 手順 4、 3の画像 2 Separating Rear Board, Unclip Covers: 手順 4、 3の画像 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. Separating Rear Board, Separate Covers: 手順 5、 1の画像 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. Separating Rear Board, Remove Ribbon Cable: 手順 6、 3の画像 1 Separating Rear Board, Remove Ribbon Cable: 手順 6、 3の画像 2 Separating Rear Board, Remove Ribbon Cable: 手順 6、 3の画像 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. Separating Rear Board, Remove Caps: 手順 7、 2の画像 1 Separating Rear Board, Remove Caps: 手順 7、 2の画像 2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. Separating Rear Board, Remove Screws: 手順 8、 3の画像 1 Separating Rear Board, Remove Screws: 手順 8、 3の画像 2 Separating Rear Board, Remove Screws: 手順 8、 3の画像 3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. Separating Rear Board, Separate Rear Board: 手順 9、 3の画像 1 Separating Rear Board, Separate Rear Board: 手順 9、 3の画像 2 Separating Rear Board, Separate Rear Board: 手順 9、 3の画像 3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Brian W
メンバー登録日: 12/21/11
1,224 ポイント
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 346
