メインコンテンツにスキップ
Sennheiser RS120 Battery Replacement
必要な工具と部品
  1. Sennheiser RS120 Battery Replacement, Ear Pad: 手順 1、 3の画像 1 Sennheiser RS120 Battery Replacement, Ear Pad: 手順 1、 3の画像 2 Sennheiser RS120 Battery Replacement, Ear Pad: 手順 1、 3の画像 3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: 手順 2、 2の画像 1 Sennheiser RS120 Battery Replacement, Battery: 手順 2、 2の画像 2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
終わりに
15 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Gayle Dunham
メンバー登録日: 03/03/10
375 ポイント
1ガイドが承認済み
7 件のコメント
Thanks for the information - this made changing the batteries a snap.
Jim K - 返信
Extremely helpful. Thank you!
-Randy N
Randy - 返信
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - 返信
Thanks! You solved my mystery.
Marilyn Carini - 返信
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 84
今までの合計 43,723
