はじめに
This guide is meant to help a user remove the hinges on a Sennheiser headset that may be faulty and/or worn down. This is a moderately simple guide as there are no components to be removed, just 9 screws to be removed. The only tools needed are a #000 Phillips screwdriver and a T6 Torx screwdriver.
必要な工具と部品
Remove the four 8mm screws on the ear cup using a #000 Phillips screwdriver to reveal the motherboard.
On one half of the ear cup that was previously removed, there will be located a motherboard. On the other half there will be a coupler holding the cup to the hinge and allowing it to move in a 360 degree manner. Remove this coupler by unscrewing the 10mm screw with the same #000 Phillips screwdriver.
The hinges must be removed from BOTH sides of the headphones for even one side to come out. They are attached together.
